1 - 4 of 4 Posts
Just curious if anyone else has any experience with the Big Boy in regards to increasing the BTU. Mine runs great, but could use a bit more heat to get the PSI up during the run. What size gas jets did it come with? Thinking about increasing the jet size first.
I have found the same but for mine it’s the gas tank getting cold, I have ran a warming line back through the feed pump return with a fine needle valve, just keep the tender water tepid it makes a big difference
You might try contacting Channing at Accucraft/AMS.
1 - 4 of 4 Posts
