1 - 20 of 22 Posts
Hi,
Do not know about a drawing but the Harland 'shorty 4 wheel flatcar' is a kit for then.
The dimensions for the kit flatcar base are 140mm long, and 86mm wide. I cut them across the width and extend them, and you have all the bits provided including plastic wheels which are better exchanged for metal ones to add some weight low down to the vehicle. The kit(one of a series) also comes with 'Hook and Loop' couplers, and 4 'stakes'
Here is the website
http://www.h-l-w.com/Products/mini_series.html[/url}
Sidestreet Bannerworks sells the plans that appeared in the centerfold of Garden Railways magazine. Plan #34 "4-wheel flat car and high side gondola" from the August '98 issue looks like what you might want but it doesn't seem to be available. You might consider buying another of their flat car plans (the early ones were quite short) and change its size to what you desire.
Have fun,
Tom
I made some flats and gondolas from Garden Railways Plan #34. They turned out great. Plan #34 has both a Gauge 1 and Gauge 0 variant. I made mine an inch longer than the plan. I think they look better a bit longer. Mine have link and pin couplers too. The gondola sides are only half the height of the plan. Again, just like the looks. All the do-dad parts came from Ozark Miniatures. They were a fun project and look nice on the track.
Send an email thru my profile and I will send you a copy of Plan #34, if you like.
Time to get busy, Bob
Awh..shame on you Gear! You got plans and never shared with me!!!!! I love them!!!!/DesktopModules/NTForums/themes/mls/emoticons/w00t.gif
Toad
Posted By xo18thfa on 08/31/2008 10:14 PM
Bob,
How did they come out 1" longer, any noticable differance? Not sure if I was here for that year on the road or off?! /DesktopModules/NTForums/themes/mls/emoticons/unsure.gif
Toad
Hey Toad: I don't have a shorter car to compare mine with, so it hard to say what adding an inch does. But I can say that my light weight, 4-wheel rigid wheel base cars are more prone to derailments. If you hit a bump at high enough speed, the leading wheels can raise off the track. I definitely need more weight.
I think about 100 of these behind a slooooow moving Shay would be too cool.
Take care, Bob
Posted By xo18thfa on 09/01/2008 11:23 AM
Take care, Bob
Bob,
Was thinking more in the lines of my mining ops. that are in the making.
Toad
for use with R1 curves i found out by trial and error:
four weeled with rigid axles the aixles should be not wider apart than 3" and a third.
the cars being about 8" and a half long, or shorter.
the empty cars weighting between 110 and 200 grams (a bit more than one fith of a pound to about two fifths of a pound)
even with weels turned by the lokal smith from plastic or steel i got no derailments.
Posted By kormsen on 09/01/2008 10:06 PM
This is why Aristo's 20' cars work so terribly on R1 curves, rigid non-pivoting single axles on a long body lenth coupled with body mounted couplers is a recipe for disappointment. On the one Aristo 20' boxcar I bought I ended up retrucking it to make it work. I still have the body mounted couplers, link and pin, but was able to get a better range of movement with the trucks under it thru the R1 curves as the trucks are closer to the end frames.
Posted By Ole Toad Frog on 09/01/2008 3:47 AM
Awh..shame on you Gear! You got plans and never shared with me!!!!! I love them!!!!/DesktopModules/NTForums/themes/mls/emoticons/w00t.gif" border=0>/DesktopModules/NTForums/themes/mls/emoticons/w00t.gif" border=0>/DesktopModules/NTForums/themes/mls/emoticons/w00t.gif" border=0>
Toad
I don't have the plans. I have the cars themselves. I'm sure plans could be made...which was my point for posting in the first place.
Posted By vsmith on 09/02/2008 9:20 AM
Ok, show some photos cause Ole Toad is /DesktopModules/NTForums/themes/mls/emoticons/crazy.gif!!!!!
Posted By GearDrivenSteam on 09/02/2008 1:44 PM
Awh..shame on you Gear! You got plans and never shared with me!!!!! I love them!!!!/DesktopModules/NTForums/themes/mls/emoticons/w00t.gif" border=0>" border=0>/DesktopModules/NTForums/themes/mls/emoticons/w00t.gif" border=0>" border=0>/DesktopModules/NTForums/themes/mls/emoticons/w00t.gif" border=0>" border=0>
Toad
Ok, if I get the plans you want me to send them on to you?? Thing is you can make abunch of stuff out of them.
Toad
Posted By Ole Toad Frog on 09/02/2008 2:01 PM
Ok, show some photos cause Ole Toad is /DesktopModules/NTForums/themes/mls/emoticons/crazy.gif" border=0>!!!!!
Sheesh, I only keep pics for so long, gotta limited storage space ya'know. /DesktopModules/NTForums/themes/mls/emoticons/whistling.gif
Ya shoulda asked 5 years ago when I first did the project /DesktopModules/NTForums/themes/mls/emoticons/w00t.gif
Oh OK I'll look thru my archives at home and see if I still have anything /DesktopModules/NTForums/themes/mls/emoticons/tongue2.gif
Buy you a 500gb book. Has worked for me! You know you can make folders to with a name /DesktopModules/NTForums/themes/mls/emoticons/tongue2.gif
Toadster
1 - 20 of 22 Posts
