Doug,
I think that the reply as to which printer is a difficult one.
Those of us who use a particular printer will swear by it, as we haven't perhaps tried anything else.
Then there are resin printers that give incredible quality results, but right now for fairly small volume parts.
But, some do use nasty chemicals, and care must be taken.
So, really you need to decide what it is that you envision printing.
Are you going to be able to draw the parts in the computer, or just print what you can find on the internet?
For a filament printer, probably any of the newer ones will give you similar good results.
The resulting print will NOT be as smooth as the equivalent injection molded part, and work will be required to make it look better.
The common filament used is PLA, BUT that does not always do well outside on a hot sunny day, which is why I now use a filament called PETG.
There are so many filament choices these days that you may find yourself testing all kinds to find the 'right' one for you and your printer.
For myself, my need was to be able to print 1/32 scale passenger cars, but without joints, so I had to modify a printer to do that as there was nothing on the market that could accommodate the nearly 31" length. I actually print 'on end' so needed that in height.
Now there are 'belt' printers that 'may' allow successful printing in any length. Again new technology, which continues to change for 3D printing.
Perhaps you can find someone 'local' that can show you printing in person and describe the processes required.
I have found that it takes a lot of time to enjoy 3D printing and that it can be very frustrating, but also very rewarding when you get to print something which is just what you wanted.
Good luck.
Cheers,
David Leech, Canada
