Thanks to everyone who answer the 1st time around. The answers helped with another question i had. I will try and ask again . Im scratch building a structure on a 3/4" piece of plywood. I need to know what to use in putting down the dirt/gravel around the building to keep it down. I think there is a mixture of glue and something else that you use in a spray bottle. I used the mixture when i had HO trains, to put down ballast. I know i have it written down someplace, but now that i need it,I cant find it. I hope i have explained my question better this time and again, thanks for all the help. Rick
You're probably thinking of "wet water." It usually consists of a 50/50 mixture of glue (Titebond II for outdoor use, white for indoor) and water, plus a little dishwashing soap to help reduce surface tension. I've also seen matte medium used in place of the glue, but I don't know how it would hold up outdoors.
Are you thinking of water activated dry resin glue? It is made from animal by products, like horses hooves. I know when I was in HO that is what was recommended to put down ballast with. It worked well inside, but I don't know about outside. I assume that you won't be leaving your building out in the weather, so this might work too. I don't even know where you would get it, as I haven't used it in about 100 years. Actually, I think the Titebond would work better. Mix 50-50 with water, add a few drops of liquid dish detergent and spray away. Try to do it in layers so you get all of the dirt wet. Good luck with your project.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
G Scale Model Train Forum
