When someone posted this picture:
Dewey the worlds smallest camelback
I realised that I had an LGB Toytrain drive would be perfect for a kitbash based on Dewey.
I was able to use the time off I had from the flu to contemplate the project and think it thru. Go as far as adding the footplate, and this last weekend I built up the cab
The Pics:
Footplate added, screws at rear hold it in place
Footplate underside, it clips into the side of the LGB at the front
Cab front and back showing the strip plastic used to stiffen cab and pencil marks used to add cab paneling
Test fitting cab. I decided to only make the cab one window wide, it looked best given the boiler lenth
Cab built up, paneling added, its just strip styrene added over the cab panels, roof was cut down from the same failed project to boiler came from
Cab rear view, air tanks added on top of boiler.
close up cab
Underside showing framing stiffeners
Engineer figure test in place
Overheated fireman test in place
Prepaint front complete
Prepaint rear complete
Next need to add the interior cab controls, then paint.
The Pics:
close up cab
